DOLPHIN
Parallel Cooperative Multi-criteria Optimization
Joint team:
Upcoming events:
  • 6th Workshop on Theory of Randomized Search Heuristics ThRaSH 2012, April-May 2012, Lille (France)
  • 7th Summer School on Artificial Evolution EEEA 2012, 12 - 15 juin 2012, Quiberon (France)
* Open position: Permanent Research Position
Recent publications:
  • T-V. Luong, N. Melab, E.-G. Talbi. GPU Computing for Parallel Local Search Metaheuristic Algorithms. accepted in IEEE Transactions on Computers, 2011.
  • A. Bendjoudi, N. Melab, E.-G. Talbi. An adaptive hierarchical master-worker (AHMW) framework for grids - Application to B&B algorithms. accepted in Journal of Parallel Distributed Computing, 2011.
  • Mostepha Khouadjia, Briseida Sarasola, Enrique Alba, Laetitia Jourdan and El-Ghazali Talbi A comparative study between dynamic adapted PSO and VNS for the Vehicle Routing Problem with Dynamic Requests, Soft Computing journal, to appear.
  • Arnaud Liefooghe, Jérémie Humeau, Salma Mesmoudi, Laetitia Jourdan, El-Ghazali Talbi On dominance-based multiobjective local search: design, implementation and experimental analysis on scheduling and traveling salesman problems. Journal of Heuristics, to appear.
  • Matthieu Basseur, Arnaud Liefooghe, Khoi Le, Edmund K. Burke The efficiency of indicator-based local search for multi-objective combinatorial optimisation problems. Journal of Heuristics, to appear
  • Vanneschi L., Pirola Y., Mauri G., Collard P., Verel S.A Study of Neutrality of Boolean Function Landscapes in Genetic Programming Journal of Theoretical Computer Science (TCS) (2011) 50 -- 68
  • Daolio F., Tomassini M., Verel S., Ochoa G. Communities of Minima in Local Optima Networks of Combinatorial Spaces Physica A: Statistical Mechanics and its Applications (2011) 1300 - 1308
  • Rita Macedo, Claudio Alves, José Valério de Carvalho, François Clautiaux, Saïd Hanafi, Solving exactly the vehicle routing problem with time windows and multiple routes using a pseudo-polynomial model, accepted in European Journal of Operational Research, 2011
  • François Clautiaux, Antoine Jouglet, Aziz Moukrim, A new graph-theoretical model for the two-dimensional dimensional guillotine-cutting problems, Accepted in INFORMS Journal on Computing, 2011
[ more publications ]
